Perform this procedure to view PoE Power Sourcing Entity (PSE) information for local LLDP-MED on specific ports.
- Select Port MED.
- Select the Local PoE PSE tab.
Local PoE PSE Field Descriptions
Use the data in the following table to use the Local PoE PSE tab.
| Name | Description |
| PortNum | Specifies the port. |
| PSEPortPowerAvailable | Specifies the value of the power available (in units of 0.1 watts) from the PSE through the specific port. |
| PSEPortPDPriority | Specifies the Power Device (PD) power priority for the PSE port (see RFC 3621):
